joelmyer's avatar
joelmyer
Expected Solar Yield, Key West
Can anybody tell me the expected daily yield of a 250 w panel flat on the roof at 24.5 degrees N. Dec, Jan, Feb
Thanks
Joel
    Thanks
    Joel
    If you're looking for "insolation" numbers (solar radiation at ground/earth level), if latitude 24.55 is close enough, and if you know how to read these charts- here's a link to the following described data collected for that location between 1965 and 1990
    "City: ","KEY WEST "
    "State: ","FL"
    "WBAN No: ", 12836
    " Lat(N): ", 24.55
    "Long(W): ", 81.75
    "Elev(m): ", 1
    "Pres(mb):", 1016
    "Stn Type:","Secondary"
    "SOLAR RADIATION FOR FLAT-PLATE COLLECTORS FACING SOUTH AT A FIXED-TILT (kWh/m2/day), Percentage Uncertainty = 9"
    Thanks
    Joel
    Not without knowing the panel specs. At NREL you will be able to calculate insolation values.
  • I believe any answer is going to involve sheer guesstimation. Replies from SV users in Phoenix or Texas would in my estimation serve as a reliable basis for computation. A week's worth of morning dew and salt brine is going to hamper careful calculations.
    Good Luck :)
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
