TimLoon's avatar
TimLoon
Extend a Stay, Which Hose?
I have the extend a stay with one fitting. I use it to feed my grill and portable stove. I would like to back feed the RV from a 20 lb. portable tank when necessary. Easy to do if you have a 2 port setup but I only have the 1 port. I can't find a hose that fits this application. Anyone have a lead on that info? Appreciate all input. Tim
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Look for Propane Refill Adapters. I had a post with a link but the software is not being nice today and won't let me post it.
  • There is also this which will give you both a grill adapter and a tee to hook up an external tank and comes with the hoses to do so.
    https://www.amazon.com/Camco-59123-Propane-Brass-Port/dp/B0014JG7RQ/
  • sorry, meant steak saver but it won't work, a bottle refiller will
    https://www.amazon.com/Mr-Heater-Propane-Refill-Adapter/dp/B000AMC5WO
    pol to 20lber, threaded connector to hose.
  • What you have is an "Extend-A-Flow" fitting, not an "Extend-A Stay" fitting. The port that's used to feed your grill will not accept the hose needed to connect an external DOT cylinder. You need the two port "Extend-A Stay" version and the POL hose that comes with it.
  • red31 wrote:
    "teak saver" - google
    I searched "teak saver" lots of stuff made from teak for the bathroom.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
