kahoona
Jul 27, 2015Explorer II
westend wrote:
Nice work!
Are you spraying with the C/H compressor?
Yes. It's a $30 yard sale find and only needed a belt tightening and a new drain valve to work. Here in S. FL we have up to 90% humidity and it took me a while to get it to work right. The compressor heats up the air going in to it so it holds its moisture. A filter and trap mounted on the compressor won't take out the water. It needs to be large and mounted near the hose end so I have the water trap ten feet from the hose end. The pressure valve and a dust/water filter are mounted at the very end of the hose. It works very nicely.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
