BFL13 wrote:
Some here with those Schumacher brand chargers have said they will go to 16 volts in a sort of unpredictable way. In that case you should disconnect the rig's batteries first. The fridge controls have a 15.4v upper limit EG.
You have to know the charging profile of the OP's charger to answer the question.
You are correct. I have the largest Schumacher SC-12000A multi-stage charger which was dropped from their catalog about two years ago.
I mainly use it for a separate Trojan 12v battery used with a inverter to power my television and recharge a Kindle Fire when not on shore-power. I leave my Trojan 6v batteries on "disconnect" when charging with Schumacher every once in a while. The Schumacher would run de-sulfation mode when needed on my previous pair. Not required yet on the newer pair. There are no items getting power when batteries are on "Disconnect".
I have used the charger many times to start vehicles at campgrounds when the owner misused and depleted their starting battery. It should be noted that the charger only hits the high voltage when finish charging at low amps and high voltage. It does not happen in the early charging up to around 85 to 90%soc.
If one does not have a "disconnect" switch the refrigerator should be turned "off" to protect it's CPU. Don't mess with using a laptop, or charging smart-phones, etc., (using an inverter) while the charger is finishing the final 10% of charging to be on the safe side.
