js6343js6343 wrote:
But my question is for those who USE EZ Lube and do not regularly hand pack bearings. What is your ACTUAL EXPERIENCE with that approach? Has anyone here actually had grease leak back through the seals into the brakes? If so, how did that manifest itself. How did you find out. Has anyone experienced any other failures using the EZ Lube method?
Yes, my first trailer when I used them...Leaked on brakes, brakes became weak, although sometimes grabby.
I'm in the corner of not going to use them again.
If you have grease in the hub, it does no good to jam more in on a regular basis.
They need to be "cleaned" and inspected...JMHO
