pilotanpia's avatar
pilotanpia
F53 460 Engine runs very poorly when heat soaked
My 1995 F53, 460cid runs poorly after being heat soaked.
When engine is cold it runs like gang busters. After a fuel stop and the engine has soaked up the heat due to no airflow through the engine compartment, there is virtually no power at full throttle. Once above 3000 rpm it starts to get power but misses and hesitates. Once up to highway speeds the engine smooths out and runs fine.
I bought the unit with 60,000 miles on it, 6 years ago.
I have replaced the following: fuel pump, spark plugs, ignition module, both coolant temp senders, IAT sender, water pump, radiator, timing cover, thermostat and all related coolant hoses.
I replaced the fuel pump in 2017 because it would only go 35 mph. I was able to hobble it home and make the repair. It was a very easy task, once the fuel was off-loaded. The fuel pump solved the main issue and it runs well until I let it sit for 30-40 minutes during refuelling. One other note, it tends to do better in cooler climates. Not much problem at all in winter months, here in North Idaho.
Most recently, we were coming home from California and our road has one portion about 3/4 mile that is about 7-8% uphill. I could not get past 5 mph using full throttle. It usually pulls the hill at 20-25 mph.
If anyone has any ideas, I would appreciate it.
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 22, 2025
