- MEXICOWANDERERExplorerThe first underseat batteries attempted Ca/Ca construction which failed miserably. The Bosch philosophy included flat compensated voltage regulators which were set at 13.8 That value in conjunction with Ca Ca construction resulted in premature battery failure due to significant undercharging, in temperatures <10c
So the change was made to hybrid construction. This is why German OEM batteries were cruelly expensive in the sixties and seventies. The Ca/Sb battery proved to be better but few customers selected OEM as their battery replacement brand. Those were the days of 5% antimony automobile batteries. Bosch refused to budge on their corporate mandate of 13.8 volt regulation. Group 42 and 53 Bosch batteries remained Ca/Sb for many years. VRB batteries remained out of production until Delco brought out the semi-sealed Ca/Ca battery in the seventies. Now that VRB are common, the issue of housing batteries outside of engine compartments is common. Of Note are the Cadillac Allende remote batteries of the 1980's housed in the vehicle trunk, which incorporated the 1116412 Delco Voltage regulator in the CS144 alternator. The sense line to the regulator was controlled by a thermistor attached to the battery. The sense lead therefore ran from the vehicle trunk to the alternator voltage regulator. This system has been long obsoleted. - ktmrfsExplorer II
MEXICOWANDERER wrote:
I do not know of a battery under the hood of a motor vehicle that is not mistreated. Try as they might, charging system controls can and do not apply proper correct voltage for minus temperatures, short trips, lights, heater, you name it. To verify this yourself look at a corrected temperature chart, then imagine a slow-engine-speed with the alternator output barely able to maintain amperage then the voltage is in the fourteens. For -20F temps? Gimme a break. Going home and connecting the car to a battery maintainer that supports CORRECT float voltages would enhance battery lifespan multi-fold. You WILL notice that cars and trucks in frigid area that are started then ALWAYS driven long distances will have much longer battery life in frigid climes.
Hot, low and high Ph agents are infinitely more reactive than cold media. This is normal and expected behavior in chemistry. Chill battery acid in a freezer to 0F, drop a spoonfull of raw hamburger in it wait 2 hours and examine. Heat the same acid to 200F in a PYREX vessel and do the same with the hamburger. Oooooo! Now imagine the hamburger as being your eyeball.
Batteries in elevated temperature climes do not operate at ambient temperatures. I have seen 190F underhood (battery lead) temperature in summer desert areas. What "charging" voltage is correct for a flooded lead acid battery at 190F.? This temp is so severe it cannot be touched with a finger without screaming OUCH!
Battery OEM scream 120F is the absolute maximum temperature limit for even the most infinitesimal of charging. With the battery in the trunk or inside a hatch at 120F how much charging "should" it see? How about if it's discharged and needs to be charged?
These are quandaries that have no practical answer. To put it bluntly, the battery takes it in the shorts. Surplus acid batteries like golf car and industrial tolerate elevated temperatures better because they have thicker plates to absorb ablation, and more surface area on their case to dissipate heat.
Go ahead. Access those temperature charts. Compare the date versus what your charging system insists on doing...
Then wince...
I think one reason my Mercedes batteries last so long is that they are NOT under the hood in the engine compartment. The sedan has the battery under the back seat, the roadster in the trunk. Way less heat than sitting underhood all the time.
Next is the battery itself. flooded cell, but looking at the details it has different composition of other metals than the typical lead acid. Don't recall which, but looking up, adds cost but extends life.
The sedan I replaced the battery after something like 13 years, not because it was giving trouble, but because DW was driving to work long distance every day and decided with winter coming didn't want her to have a battery go bad. And in the winter we do lots of stop and go and use the "rest" function to keep the heat in the car when shopping. runs an electric water pump and fan to circulate the coolant through the heater core to keep the car at a set temp for up to 1/2 hour. Still the batteries last a long time, same treatment with the roadster. - pnicholsExplorer II
Sam Spade wrote:
Will batteries fail sooner if exposed to high temperatures?
I thought about it for awhile - then realized how much it didn't make sense.
If reallly true, then a question is begged: Since underhood air temperatures are always "high" around a battery under the hood whenever a vehicle is driven ... does this mean that the more you drive your vehicle the quicker it's battery will die??
I think not. I think the key to long battery life is keep them fully charged (without bubbling away electrolyte) as much as possible. Sometimes personal vehicle batteries get let go too long without a maintenance charger on them or if whenever they are driven ... they may not be driven long enough to replenish the charge that was drained when the engine was started or driven long enough to replenish lost charge from sitting too long between drives. - MEXICOWANDERERExplorerI used to grimace when a customer brought back one of my "piece-of-junk" RV alternators, chewed my ass for 20-minutes, then stomped out cursing to return in a few hours.
I'd pull the alternator apart and find ALL THREE TATTLETALE diodes blown, and the only thing on the face of the earth that would blow those 1000 PIV diodes is REVERSED POLARITY. About one in ten wouldn't admit it. They walked away poorer for their stupidity. The others got their screwups fixed for parts cost alone. "But I only touched the cable for a second and stopped when I saw a spark".
This is not a one-way street. The problem was so serious with batteries I made a good income ferreting out the truth and then doing my best to correct it.
The phrase "Screw Up A Steel Ball With A Feather Duster" has a lot of merit to it. Finding and correcting the actual problem works miracles. - Sam_SpadeExplorer
mkirsch wrote:
Battery manufacturers will make any excuse they can to shift blame for a mediocre to shoddy product. Too hot. Too cold. Too wet. Too dry. Too much use. Too little use. In the end you always end up paying for the new battery.
And tire dealers too. Sub "tire" for "battery" in your statements above.....and add potholes. NO tire or battery ever failed due to defective parts or workmanship. - Sam_SpadeExplorer
pnichols wrote:
As always, these type discussions always seem to assume liquid (wet) acid batteries. AGM (dry) batteries are a whole different animal.
And as always, some seem intent on ignoring the simple original question and running off on a tangent.
High temperatures adversely affect ALL batteries, some to a different degree. AGMs last longer in almost all circumstances but it has little or nothing to do with resistance to temperature extremes.
So, the original question was: Will batteries fail sooner if exposed to high temperatures? And the answer is a resounding YES.
The only exception might be a "dry charged" one that has not yet been activated by adding electrolyte. But then it is not a real battery......yet. - mkirschNomad IIBattery manufacturers will make any excuse they can to shift blame for a mediocre to shoddy product. Too hot. Too cold. Too wet. Too dry. Too much use. Too little use. In the end you always end up paying for the new battery.
- MEXICOWANDERERExplorerI do not know of a battery under the hood of a motor vehicle that is not mistreated. Try as they might, charging system controls can and do not apply proper correct voltage for minus temperatures, short trips, lights, heater, you name it. To verify this yourself look at a corrected temperature chart, then imagine a slow-engine-speed with the alternator output barely able to maintain amperage then the voltage is in the fourteens. For -20F temps? Gimme a break. Going home and connecting the car to a battery maintainer that supports CORRECT float voltages would enhance battery lifespan multi-fold. You WILL notice that cars and trucks in frigid area that are started then ALWAYS driven long distances will have much longer battery life in frigid climes.
Then wince... - pnicholsExplorer IIAs always, these type discussions always seem to assume liquid (wet) acid batteries. AGM (dry) batteries are a whole different animal.
This past summer I replaced two AGM RV batteries that were about 8 years old that still seemed to have plenty of life left in them ... they were kept on a maintenance charger 24/7 when not in use.
I have a larger (Group 31, 95 amp hour) yellow top Optima AGM battery that is at least 15 years old and it will still start our car ... I top up it's charge only a couple of times a year.
Finally .... after owning our 4X4 PU for 18 years .... this past summer I put an AGM starting battery in it because I got tired of replacing liquid acid batteries that continued to let me down after being in the truck only a few years.
You can replace a bunch of liquid acid batteries or replace only a very few AGM batteries. - GjacExplorer IIIAll things equal I think batteries will last longer in a colder climate. The problem is things are not equal. Most on here are posting how long their car batteries last. My Walmart Max starting batteries for my cars last about 3-4 years in CT, but I don't maintain them like my MH batteries. I just drive and park them. My MH I recharge my 2 Sams Club 6v CG batteries when they self discharge to 95% SOC and charge the Walmart Max starting battery at the same time. I also equalize maybe 2 or 3 a year. These batteries are over 9 years old and still going strong. The colder the temps the slower the self discharge is, but I think maintenance plays a much bigger role in longevity.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
