dougrainer
Sep 30, 2018Nomad
smiggleburger wrote:
I recently discovered that my third Dometic 15K BTU AC in three years has failed again. Just like the last two times, it powers up, the compressor kicks in and blows air with zero degrees of cooling. Since the last one was installed in December of 2016, there is a good chance I can get it swapped again under warranty.
At this point I have no faith in Dometic air conditioners. I understand they had problems when manufacturing was moved to China.
I am ready to go into my pocket and buy a brand that is hopefully made in the US.
Has anyone had a Dometic AC installed or purchased a new RV in the last year or so and if so what have been your experiences with the Dometic?
Your warranty expired almost 1 year ago. Warranties only are viable for the duration of the ORIGINAL warranty date. You do not add on to the date the replacement was installed. But, you have a good case to get Dometic to step up and warranty this 3rd unit. You need to make sure you bring this up BEFORE the Service Center starts the warranty claim. They need to make sure Dometic understands, this is the 3rd AC in less than 2 years, so they need to proceed knowing the history of your RV. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
