Big_Katuna
Oct 01, 2018Explorer II
dougrainer wrote:Big Katuna wrote:
So how many milliseconds does it take for that relay to open if you turn off the main breaker while it’s running?
You need to get a life:) Doug
Couldn’t respond as I was driving all day.
My question was going somewhere. When you remove ac from a motor or inductor, there is an inductive that can be quite high.
So if the relay opens, the inductive kick goes now where but if you throw the breaker the inductive kick back feeds through the relay and associated components will see the volts.
