ScottGNomadJul 20, 2018Fan for fridgeI am installing an ARP protection system on my Norcold and the unit has built in fan control. The fridge has an existing little fan mounted in the middle of the back side between the upper and lowe...Show More
Old-BiscuitExplorer IIIJul 20, 2018Fan in roof vent will not be an obstruction........cause you will set it to run based on 'temp sensor'OEM Fan thermostat is attached to condenser fin at top of fridge and closes at 130*F --- opens at 115*F (CONDENSER FIN Temp)APR Temp sensor is attached to lower absorber tube and on/off temp can be set 90/75 up to 140/125 *FEnhanced airflow/draft means more HOT ammonia vapor condensed into liquid (condenser) ....more liquid condensed/more cooling affect.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
Related ContentTroubleshoot fridge problem...Fridge Vent Fan QuestionsFridge cooling fan modNorcold Model 611 Fridge problemOverkill Fridge Fan
