I am installing an ARP protection system on my Norcold and the unit has built in fan control. The fridge has an existing little fan mounted in the middle of the back side between the upper and lowe...
I have a 10 cu. single door Norcold. I installed a small muffin fan to the lower area that I turn on in hot weather. I have it raised slightly so air can get uner it and it blows upward. The air flow helps the fridge quite a bit. I hook the 12V to one of the wires on the fridge. I just wish I had a thermal switch. But it works great. You will be very happy with your results. The idea is to cool the fins on the top and to increase air flow.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
