rbhjhh wrote:
where is the best place to buy the parts i need for my duo therm 630035.321. i think it is penguin
Thanks
Yes, it is a Penguin. HOW do you know what parts you need???????? Doug- rbhjhhExplorerwhere is the best place to buy the parts i need for my duo therm 630035.321. i think it is penguin
Thanks rbhjhh wrote:
I have 2001 monaco diplomat, duo therm air conditioner /heat pump.
ONLY 2 things will cause this on your Dometic system
1. The ZONE on your tstat is NOT set to the one on the affected AC unit. Make sure you can see BOTH Zone 1 and 2. 2001, you may have the original 4 button tstat instead of the updated 5 button. IF you have a ZONE button you have the 5 button. IF you have NO Zone button you have the original 4 button. If you have the 4 button, do you know how to change Zones?
2. Your upper main control board is bad, it will need replaced. Doug- ernie1Explorer IIThe relay that is powering the fan has the contacts welded together. Get another relay.
- j-dExplorer II
Better if you can post the DuoTherm model, and that of the Thermostat as well. - rbhjhhExplorerI have 2001 monaco diplomat, duo therm air conditioner /heat pump.
- bullydogs1ExplorerWhat brand is your AC?..and your coach...This happened to my wireless carrier unit and I found out that it didn't like the wifi hot spot close to it...Once I moved it...it resolved itself..
- rbhjhhExplorerIt is set on auto, even when I turn the termostat off the fan runs, I have to click the breaker to get it to stop. Thought it might be thermostat.
- 96Bounder30EExplorer IIMoved from Class A Motorhomes
- sch911ExplorerCheck thermostat, make sure it's set to Auto and not to On.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
