MEXICOWANDERER
Jun 20, 2014Explorer
Seen lots of these motors with burned windings. Would recommend you take a peek. Low voltage starting is the culprit. About five to one ratio, burned fan motor versus failed compressor motor. Good luck. Hope you can get away with just a run cap. I rigged up 110 uf caps setup on the power source for the fan. End of voltage startup problems.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
