joelyn
Jul 18, 2019Explorer
2 many 2 wrote:
Just as an ancillary response, I am glad the OP has solved his problem (we hope) :C
I never use the automatic opening and closing switch. I am too impatient to wait for it to open or close, so, I always just pull the handle down and open or close it manually.
That's just me............:B
My fan must be a older model because my handle on the left motor does not have the pull down handle to open manually. Its a fixed handle that goes right into the shaft.
this is the lift motor i have and I believe the newer models have the lift motor right above mine where the label says manual etc.. NOT SURE IF THEY ARE INTERCHANGEABLE OR NOT. Maybe someone would know. The second link is the other motor for I believe newer fans with the pull down.
lift motor K6010-81
newer lift motor
