hypoxia
Nov 17, 2015Explorer
MEXICOWANDERER wrote:
Can I safely asssssssume the vent fans use the same motor as the box Endless Breeze fan?
The Breeze motor has a different mounting configuration than the ceiling fans, at least mine are different. I was going to switch one around but I think it was the hole pattern that was different. I took photos but can't find them now.... This is the Breeze motor. The tape covers the small hole I drilled to lube the bearing/sleeve.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
