subcamper
Nov 17, 2015Explorer II
I replaced the brushes in my FF last year because they had worn down so much that the fan became intermittent.
I drilled out the rivets to open the case.
For replacement brushes, I used some Harbor Freight replacement brushes that I had lying around. They were a little too wide, so I sanded them down to fit. The hardest part by far was to hold the brushes retracted while you close the two halves of the motor. The commutator doesn't end up under the brushes until the motor halves are almost touching. I used some bent paper clips to hold the brushes retracted, with part of the clip hanging outside the motor case. Then I pulled them out to release the brushes as the motor halves closed. The permanent magnet is very strong, so as you get them close they snap together.
Steve
Steve
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
