MEXICOWANDERER's avatar
Nov 16, 2015
Fantastic Fan Motor Brushes / Bearings ?
I have no way of sourcing information about the vent fan motors. Can I safely asssssssume the vent fans use the same motor as the box Endless Breeze fan?
Do these critters use ball bearings? or do they use sleeve bushings?
Anyone out there ever re-brush and re-bearing a Fantastic Fan motor? Successfully?
Replacement motors cost as much as a new fan, and frankly I am out of storage room in the toad. Bearings and brushes would take up a lot less space.
Gabriel, loves to re-build supposedly non-rebuildable heater and AC motors. He drilled the spot-welds in my K-car radiator fan and hand fitted brushes to size with a fine grain honing stone. I came up with a 6volt high-amp transformer and carbon graphite rod and clamp which serves to spot weld new attachments.
But really weird brush design and odd size bearings need to be fathomed before the still-working-fine fan motor comes apart. The motor has in excess of 10,000 hours. I know the fans are reliable but that is too many hours to take lightly. Where I live, a fan can stay running for months day and night. It is used on 12 and 120 volts. I am going to rebuild it before it blows up. Why? When brushes give out the tension spring beneath gouges the commutator. The motor runs just long enough to screw up a perfectly good armature.
Tips, hints, gossip, snide remarks, and high-quality sarcasm are all welcome. Thanks.
  • Is this the motor?
    http://www.ebay.com/itm/Fantastic-Fan-Motor-for-12-Volt-DC-Fan-Powered-Roof-Vent-RV-Motorhome-Parts-/201456249578?hash=item2ee7ba6aea:g:AUMAAOSwQTVV8jty&vxp=mtr
  • RLS7201
    Thank you kindly for the clarification. I'm soooooo deef, a motor can screech and make alley cats a mile distant arch their back - and I'd never hear it.
    A splootch of good grease and it'll be ready to rumble, err...I mean run.
    I wonder if the brushes are weird? If I could get an idea of what they look like, I'll order an assortment and let Gaby work his magic. I'll mike the shaft and bore and order a dozen bushings. I got some more chicken head switches, the ones that are rated for a zillion cycles.
    Lake Atitlan gets chilly in the morning. A nice wood stove and fan should take the worst of it off.
  • I think 4 of these would fit in a 14 inch square opening:
    SilverStone Technology Super Slim 180mm Fan with Speed Adjustment Cooling FM182
    http://silverstonetek.com/product.php?pid=532&area=en
    I have the SS AP182 fan, but it does not enjoy charging voltages at max speed, so I limit it to 11 volts at all times.
    Mine just ran at various speeds from march to last week continuously.
    A bigger fan FF is likely more efficient than 4 of these, except on Low speed. They claim 0.05amps at slowest speed. My AP182 does in fact draw that amount at slowest speed, and is silent and still moves some 60CFM.
    Anyway, not an option likely to be employed, but an option none the less.
  • Mex,
    Most motors used in a homosapien habitat are bushed. Balls and rollers are noisy.
    Richard
  • Expecting a response from yourself?
    If a person can't take the heat stay outta da kitchen...When I do something dumb yotta hear the sarcasm. No one is immune in my book.
    What are you folks telling Fantastic Fan? When I told them I needed a motor they were kind enough to respond that a motor cost almost as much as a new fan and as an example, a new switch costs 22 dollars. Buy it in separate parts and a new fan will run around 200 dollars. No brushes and no bearings available.
    Could it be these kind offers you report are from the distant past? From their attitude when the warranty she go, they will be overjoyed to sell you a new fan.
  • MEXICOWANDERER wrote:
    . . . . . Tips, hints, gossip, snide remarks, and high-quality sarcasm are all welcome. Thanks.
    Expecting a response from yourself? :B:B
  • I gave up on them after multiple failures. Replaced it with one of those cheapy units with the little fan... works almost as good.
  • rrupert wrote:
    You should contact Fantastic Fan, they are very good with taking care of its customers. You very well may get free replacement of the parts and have to pay for shipping only.
    Very true!
    Even after Atwood acquired them back in 2010 (same makers of Endless Breeze and Ultra Breeze 12V fans)
    I haven't bother with taking fan motor apart.just contacted them and they sent new motor FREE
    Think motors use bushings......bearings are more 'Upscale' :B
    ftvservice@atwoodmobile.com
    800-521-0298
  • You should contact Fantastic Fan, they are very good with taking care of its customers. You very well may get free replacement of the parts and have to pay for shipping only.
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 27, 2025
