down_home
Aug 03, 2015Explorer II
With cover closed and fan off position,Pull the knob down and adjust til it is closed snugly but not too tight and push the knob back up.
use a very little talc powder on the seal. The motor will tighten the cover way down, if that is where it is adjusted to.
Also had the operating arm held by one screw at each end pull out from over tightening.
Plastic and heat from sun etc against rubber seal will stick, but usually it is the motor over snugging the cover down, causing it to stick, usually after someone has operated it manually, for some reason.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
