MrWizard
Jun 07, 2021Moderator
If it's a simple mechanical thermostat it's just a bimetal strip with contacts, the temp adjust can set either the gap between contacts or the preload against the movement of the strip to close the contacts, I would start by removing the stat from fan and cleaning the contacts
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
