mr_andyj
Jun 08, 2021Explorer
MrWizard wrote:
If it's a simple mechanical thermostat it's just a bimetal strip with contacts, the temp adjust can set either the gap between contacts or the preload against the movement of the strip to close the contacts, I would start by removing the stat from fan and cleaning the contacts
I will try this before calling Dometic.
Side note - the fan has 3 speeds. Fast is power directly to the fan, while med and slow go through what looks like a heating element of two different sizes. I assume this "burns" off some power which then reduces the power to the fan and thus a slower speed. Conclusion, all 3 speeds use the same amount of power. Conclusion, it is better to use the high speed while the thermostat is on for maintaining temps while you are away (it will run less than a slower speed). Use the slow and medium speeds for comfort/noise level while inside.
or does fast use the least power?
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
