MEXICOWANDERER
Jun 03, 2013Explorer
Just in case the WD-40 trick does not work...
Unless the motor was operating 24/730 or jammed and left switched on, it is improbable that the motor wore out or broke. Do yourself a favor and connect a 12-volt test light wire clip end to the ground wire bitter end where it runs into the rig, then touch the test light tip to the power inlet. Got power?
I wonder if the Roof vents and the Endless Breeze models use the same motor?
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
