ken_burke
Jun 04, 2013Explorer
donn0128 wrote:
You might also pull down the inside cover and look closely. On mine it did not work after installing a new roof. Turned out to be one of the wires from thermostat was not connected. While your there you can trace the 12VDC and ground to be sure you actually have 12VDC up there. Good chances you dont. Did you actually check the fuse???
Yes, the fuse is okay. As I understand it, the only thing that the thermostat does is open and close the lid. It does not have anything else to do with power to the motor. When the lid opens, the plunger switch opens and completes the ground to the motor.
I have a good fantastic fan electrical diagram that I will try to send to you later.
ken
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
