- pianotunaNomad IIII'm assuming an essential feature would be an ability to set the output voltage.
- pianotunaNomad III2oldman,
Thanks for the clarification. - 2oldmanExplorer II
pianotuna wrote:
Yes, it's a 30a 48->12 'buck' converter. No. I think we're talking about two different animals.
Does your existing converter allow you to run the slides? I'm assuming you are running the converter from an inverter? - pianotunaNomad III2oldman,
Yes I knew you have a 48 volt battery.
Does your existing converter allow you to run the slides? I'm assuming you are running the converter from an inverter? - 2oldmanExplorer II
theoldwizard1 wrote:
Sorry... OP knows I have a 48v battery.2oldman wrote:
The power to run your slides is going to come from the RV batteries.
My main concern was amperage. Enough to run my slides. - theoldwizard1Explorer IIInteresting video !
"It is possible to damage your AGM or LiFePO4 batteries charging them from an engine alternator."
Renogy DC-DC Battery Charger Review: "Smart" Alternator Charging - Primary feature is amp rating. JMHO. Bigger is not always better and watch the input amps. The rating is output.
The power to run your slides is going to come from the RV batteries. If you do not have a RV battery, I doubt that these chargers would be able to run the slides.
If the batteries are heavily discharged, you will have to run the vehicle engine for some time (15-30 minutes ?) to charge those batteries and operate the slides. - theoldwizard1Explorer II
pianotuna wrote:
What features should one look for in such a device?
• Wide input voltage range (maybe 11.0V - 15.0V)
• Programable for multiple battery types (flooded lead acid, AGM, LiFePO4 and ?)
Bonus (low priority) would be a way to use the RV battery to boost the engine start battery, but that would have to go through the fuse in the vehicle so that would be the limitation. - theoldwizard1Explorer II
BFL13 wrote:
One thing that came up was to have one that is buck/boost where some new charging systems let the starting batt run too low at 12.x and at times it is too high at 15.x.
If a DC-DC charger can NOT boost a voltage from <13V then it is useless ! Protection from overvoltage is a bonus as is discharge of the RV battery.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 31, 2025
