ewarnerusa
Feb 10, 2023Nomad
Chum lee wrote:
As previously hinted at, if you have a 2/3 way absorption type fridge, why not divert the excess power generated to that and save some propane? Clearly, if you have a 2 way fridge, you'll need an efficient inverter capable of generating at least +-500 watts on a duty cycle of at least 50%. Just keeping your 1500 watt PSW inverter online full time may be enough to waste enough excess power to solve your issue doing nothing else. IMO, 280 watts of solar wont be enough to run the fridge full time, but hey, it's a start. You'll be spending a lot of time doing load management.
Chum lee
A different take on this idea^^ I wonder if instead of a 12V water heater element I could explore a refrigerator 12V element? Is there harm in adding variable/inconsistent heat (less than the OEM 300 watt AC power element) to the ammonia in an absorption fridge? This is just a brainstorm, I definitely don't want to swap out the AC side of the fridge.
EDIT: I clearly don't know exactly how the ammonia is heated in an absorption fridge, just that this is part of the process. But first google search showed a promising success for a similar idea. This is a Dometic fridge, mine is Norcold. https://www.escapeforum.org/forums/f8/adding-12v-heating-element-to-rm2510-fridge-16224.html
