StirCrazy
Feb 13, 2023Moderator
Cptnvideo wrote:
"IMO, in order to actually use excess solar capacity, add battery storage capacity so the excess power can be used when needed."
Exactly. That is the correct thing to do.
Not realy though, that only works if you also increase your daily usage.. for instance if I say doubled my 280AH on my camper for 560AH all it would do is let me go 18 days with out the solar producing at all instead of 9 days, the chances of that happening are close enough to 0 that it would just be a waist of money and equipemt. extra weight and so on. you have to decide how much reserve you need and if you don't have enough this would be a good idea but once it is topped up your in the same boat, so unless you plan to use that exra capacity its not realy that good of an idea.
