Terryallan
Aug 17, 2013Explorer II
If hitting the tree cracked the gelcoat. Maybe you should get it checked to see if it cracked the glass as well. Glass often moves with the gelcoat. If it cracked one, it could have cracked both, and not fixing it correctly could be costly in the long run. Think water getting to the wood laminate. Bad thing
The black you are seeing is the fiberglass.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
