- Legs should come straight off the battery. Look around the battery for a fuse or circuit breaker. Some circuit breakers have small reset button.
- CincyGusExplorer II
bid_time wrote:
Dead battery or disconnect switch in off position.
What he said. Legs run on 12v power so the motors not getting power until you plug in. $ to a donut it's one of the two or a bad ground from the motors negative wire. - bid_timeNomad IIIDead battery or disconnect switch in off position.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
