Padlin's avatar
Padlin
Figuring Proper Fuse Size
Hi folks, looking to install solar and an inverter on a new trailer and am looking for someone review my fuse needs, here's the scenario.
dual 6V batteries, 230A.
1500w Inverter, 125A
Solar Controller, 30A
Converter, 55A
Connecting the battery - via 2awg to a 500A shunt to feed a Trimetric Battery Monitor
Battery + via 2awg to a Main fuse.
Main fuse to 3 way power distribution block.
Fuse for inverter leg 150A, 4awg
Fuse for converter leg 60A, 8awg
Fuse for solar controller leg 40A. 8awg
Question, what size should the Main fuse be? do I even need a Main fuse?
Any other suggeations?
  • westend wrote:
    You will need a main fuse within 18" of your batteries. A 100 amp fuse would protect your 2 AWG.
    How can I use a 100A fuse in a circuit where the Inverter could possibly draw 125A?
    BFL13 wrote:
    You could use the inverter pos terminal as a buss for the converter and solar controller branches off of that. Makes the inverter fuse the big one.
    I take it all fuse values remain the same?
  • You will need a main fuse within 18" of your batteries. A 100 amp fuse would protect your 2 AWG.
  • You could use the inverter pos terminal as a buss for the converter and solar controller branches off of that. Makes the inverter fuse the big one.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
