rk911
Sep 22, 2016Explorer
Horizon170 wrote:
New to me Coachman (See signature) and I can't find how to tell when the tank is full. Yes I know about the inside gauge that shows levels of all tanks but when outside how do I know when to turn off the water as I don't want to burst a pipe inside?
Also how do I know the water heater is full when I have the bypass in the correct position for getting hot water?
I've been RV'ing half my life but this is the first time I've had a CLOSED system. All others had an overflow. Nothing in the Coachman book about it. Do I crack the sink faucets?
Thanks for understanding.
Marvin
are you sure there isn't an overflow on the fresh tank? da water has to go somewhere so if no overflow then expect to see it spilling out of the fill tube. the hot water tank takes in water as needed to keep it full.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
