tred0956
Sep 22, 2016Explorer
On my Coachman. the fill port is a threaded fitting to fit a garden hose, so there is no overflow out the fill tube as there is in most other RVs. There is an overflow linked directly to the tank. You can't see it but when the tank is full, you will see the water come out, probably under the frame. Mine is directly over the back axle. Just hook her up, let it flow and turn her off when water starts splashing on the ground!
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
