swimmer_spe's avatar
swimmer_spe
Filling the water tank at home
We used to live where we had city water. We have since moved and now draw our water for our home from a lake. It is perfectly safe and clean, however, some sediment might get through and there can be discolouration. While that doesn't bother me at home, I worry about what I put in my RV tank.
Would you suggest filling it at home or at the campground?
  • I am the OP. I am also a stationary engineer. Pure water is partly my domain, but there are water specialists that make sure our water is perfect. The tests for boiler water is different than the tests for drinking water.
    Someone say Boiler Deaerator?
    How do I make my signature say
    I'm no expert but I play one on the internet?
  • "stationary engineer", heh I was trained as a machinist mate in the USN which is the equivalent and went to Reactor Operator and Engineering Lab Tech before going back to school post Navy. I also worked in a utility with 2200 psi boilers. And boiler water has all sorts of boiler treatment chemicals in it, phosphates, probably some organics like morpholine or cyclohexylamine and so on depending on the unit pressure. Now feedwater is pure until you load it up with chemicals.
    Yes you need to be concerned with what but what I would put into a boiler or reactor is not what I would drink...heh.
    Admiral Rickover picked up a beaker of water of some kind and drank it down, on TV, claiming it was reactor water. LOL what a liar, the barium or Lithium Hydroxide might have produced some gastrointestinal fireworks plus the stuff is mildly radioactive.
    Yes you need to be concerned with what but what I would put into a boiler or reactor is not what I would drink...heh. Admiral Rickover picked up a beacker of water of some kind and drank it down, on TV, claiming it was reactor water. LOL what a liar, the barium or Lithium Hydroxide might have produced some gastrointestinal fireworks plus the stuff is mildly radioactive.
    In non glow-in-the-dark boilers, I would not put the water in my tap into them. I would also not drink boiler water.
    My concern still is whether the sediment build up should be a concern. I usually only drain the tank to winterize.
    ... won't get the pH up. And, still doesn't deal with the sediment.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
