MEXICOWANDERER's avatar
Jul 27, 2015
Finally Found A 48-SMD 12-Volt Panel
Yeah Yeah Yeah
My aged eyesight ain't so hot. I need bright light. Until I tried this plate I might as well have been using a night light to see by. Since I am a law ignoring tax evading shopper that screeches at shipping fees I found something that doesn't give my wallet the Willies...
http://www.buyincoins.com/item/37568.html#.VbaZFrWrEm0
If you demand Wal-Mart parking lot golden light you gotta go somewhere else. Or wear glasses with amber lens.
  • The description says 240lm not 270lm. I got 500+lm from Command Electronics a few years ago for a lot more money. I see Command doesn't sell them anymore, they weren't competitive with the cut rate China direct sellers.
    I'm pretty sure a 921 is around 240lm - 250lm.
  • I think mine are half the lumen output and yet they are plenty bright for camping.
    Excellent price.
  • Might be just me but to my age ravaged eyeballs, the light output from a 921 competes with a fire fly.
  • MEXICOWANDERER wrote:
    I have tried the eBay 48 chip models years ago and they were around half as bright as these. These little monsters are rated at 270 lumens and for the life of me, I think they really put out 270 lumens. The companies lie about supposed specs so much only real world eyeball comparison works for me.
    I would rather team these up with a dimmer than play virtual Kelvin-O-Matic by mix and match. So there goes a Tijuana-Transmitter regulated lamp. Grounded Window screen glued to the inside of the dimmer cover stops any nefarious transmitter ideas of the PWM dimmer control. The dimmers are not noisy in my environment but HAM Radio operators may encounter a different reality. Barking burros and braying canines drown out all but the most pervasive audio interference. Being deaf also helps.
    Each of mine is pretty much equal in brightness to a 921 bulb. About .40 to .45 amp vs 1.5 amps each bulb
  • I have tried the eBay 48 chip models years ago and they were around half as bright as these. These little monsters are rated at 270 lumens and for the life of me, I think they really put out 270 lumens. The companies lie about supposed specs so much only real world eyeball comparison works for me.
  • I bought those on Ebay in 10x lots for $18.00 for 10, a couple of years back. I like /prefer mixing a 3300k with a 5700k per 2 bulb light fixture, for a more natural, less yellow color.
  • RoyB's avatar
    RoyB
    Explorer II
    Mex - Those type boards are what Ihave been using since 2009... i tried a bunch of the higher cost items and all of those would generate RFI and interfered with my radio ops... Finally got those led boards and run them in my ceiling light. I paid alot more than you find however... $4.99 a board from ebay/china haha... My board were rated for 12-14VDC and I was concerned I might blow some LEDs when my setup went to bulk charging of using 14.4VDC. Since 2009 I may three or fours groups of three leds off in the boards. I bought ten extra boards to replace the one that might burn out me - still got ten new ones in a box waiting to be used...
    About the only problem I have over the years is the sticky tape losing it grip and the boards dropping down inside the light fixture. I just get some more doublesided sticky tape and all is good for another many moons.
    Since I had a bunch of higher cost boards I did come up with a multi-switch ceiling lamp assy. It would turn on ONE or BOTH lamps. I put the cheap $4.99 in the ONE POSITION and the higher dollar one in the other position. Then I could just turn on one lamp that didn't interfere with my ham radios when I was playing my my ham radio items...
    I guess my boards were the 36 LED boards... These were plenty bright for me...
    Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
