12th Man Fan wrote:
You may want to verify this but I have saw a post on here where the lifetime warranty is voided if you install it yourself. Must be installed by professional.
Just FYI if you plan to install it you might want to verify this.
This is old and not true,it has been discussed here many times and I have called the company about it and here is the Warranty.
Limited Lifetime Warranty
Our Lifetime Warranty covers only
Progressive Industries workmanship, internal electronics and
parts & materials contained within the unit housing. Any and all damage to the outside of the unit is not covered.
External damage is typically associated with a poor connection between your RV or our EMS/SSP units and a power cord. The Lifetime Warranty
does not cover labor or shipping charges.
Our Lifetime Warranty is exclusive to Progressive Industries and is granted in lieu of all other express or implied
warranties, obligations or liabilities.
This is a non-transferable Lifetime Warranty.It applies only to the original owner and covers only those
products purchased from an authorized dealer, retailer, or seller.
This warranty covers manufacturer
defects in materials and workmanship.
A proof of purchase is required for all warranty claims.
The follow are excluded and not covered by the Lifetime
Warranty and/or void the Lifetime
Warranty.
Improper installation of a hard wired unit
We strongly recommend that a competent electrical
professional perform the installation of hard wired units.Products installed or used in an application other than an RV
Products operated outside systems compatible and compliant with RV surge protectors.
Products used in a manner inconsistent with the operating instructions
Use of replacement parts or accessories that are non-compliant with Progressive Industries specifications
I installed mine as instructed in the
Company Video and the tech I talked to said that it would be covered,I have had no problems except the failure of the remote unit,which they agreed that there were problems with the older units. They sent me a free replacement overnight.
