Cummins12V98
May 11, 2018Explorer III
Ralph Cramden wrote:
Your siding is thin, most likely .024. It's stapled directly to 2X studs turned on the flat. Just push with your thumb on the lows and you'll find the studs.
As far as finding them from inside I find it hard to believe Dutchmen Mfg has filled the staple holes so well they are not visible. And the seams are covered with a 1" strip of vinyl wall covering (seam tape). The seam tape is at a stud, and so are the staples as those inner panels have no additional backer panel behind them, they're just 1/8 Luan.
I would have the studs marked in a couple minutes. Not bragging just experience speaking. Many just don't have the experience, NOT being critical.
