brulaz
May 13, 2018Explorer
brulaz wrote:
With mine, as long as the inverter power switch is off, no power is drawn.
After reading time2roll and the wiz's replies above, I should change this to "little power is drawn", possibly a few milliamps?
Say 10mA, or 0.24 Ah per day, or 3 Wh per day?
According to the daily solar charging logs when in storage, typically 50 Wh per day were used to maintain the batteries when all other parasitic loads are disconnected (other than the inverter, turned off, and the solar charger). So prolly not a major issue relative to battery self-discharge.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
