CA_Traveler's avatar
CA_Traveler
Explorer III
Dec 25, 2014
First Solar Harvest
Comments appreciated
3x250W serial connected panels, flat mounted (4 degree slope), no shadows on 12/24/14 in Oceanside, CA (33.2117° N) and MS MPPT 60 controller. There were high clouds by 10am and variable clouds for the remainder of the day. Batteries were fully charged at the start so DC loads were added that exceeded the controller output during the day.
Solar harvest was 113 AH for the day. Does this seem like a ball park harvest considering the short days, low sun elevation and clouds?
Controller Amps Output
Panel Specs
  • It would be "nice" to validate the solar output with someone in the same area with a flat install. Next summer the "sun till tilt" and be closer to aligning itself with my panels. I'm tracking several other variable that I can make available if that is helpful.
    I'm planning on power from 3 flat panels to be equivalent to 2 tilted panels.
    As I've posted before the average person tilts their panels 7 times. My average will be 0 times.
    Requested that the installation thread be moved to this forum.
    If the batteries were fully charged at the start, wouldn't that significantly decrease the need for amps, hence the very low 113ah?
  • It is hard to tell what you should be getting to see if your set-up has any "issues" unless it is clear blue at high noon. And then the panels have to be pointed at the sun, not flat, to use your panel ratings for your "expected amps."
    At least your curve is the right shape, so that's a good sign.
    Your installation photos would look good in this forum instead of the other one :) Probably go in the forum library thread with the others too.
  • As you pointed out, a lot of variables to this solar stuff.
    I have 710w, 2 8d batts and run a unline icemaker about 16 hrs a day threw a 2 k inverter. Daily harvest averages 160-215ah while out camping. Heading to Salton sea all next week. Will post some averages when I get back.
    Congrats on your solar your gona love it!
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
