MNtundraRet wrote:
Your Iota did go into "bulk" charging within a few minutes, and the output voltage would have been 14.8 volts. To see it you would need to read the voltage at the charger output terminals. Your converter/charger was working since to read the current (amps) outputting maximum rated 55 amps.
I understand now. My readings were taken from the Victron which is not at the output terminals of the converter. I think Sal would call this a measurement error. :) BTW, I'm not worried about the charging time, I'm not expecting this to be quick. Next time I'll check the converter terminals.
