pasusan's avatar
pasusan
First time with an inverter
Our Roadtrek has an inverter for the TV & DVD player. There is a switch to turn the inverter on and off, and the TV & DVD don't work unless the switch is on. So, even if we're on shore power we have to turn on the inverter to watch a movie. Problem is we forget to turn it off when we go to bed and it runs all night... The owner's manual says to be sure to turn it off when not using.
Is there a way to switch to shore power when we're hooked up or maybe get a lighted switch for the inverter so we are reminded that it is on?
How does the average inverter user handle this?
  • pasusan wrote:
    BFL13 wrote:
    Leave the TV and DVD on and just use the inverter switch to turn them on and off.
    Our inverter runs other things too so we have to actually unplug the TV since it is still on in standby drawing power when it is "off"
    Thanks for that - we'll try using the inverter switch to turn things off. If we can't seem to do it we'll end up replacing the switch with one that is lighted while on.
    You can use a night light that goes in a 120v receptacle as a reminder. I use my three-light tester for that instead. If no receptacle free with TV and DVD plugged in, you can use a power bar to get more receptacles.
  • 2oldman wrote:
    This average user usually leaves it on 24/7. Probably harder on them to be turned on and off frequently.
    Ours is from 2004 (probably 2003) and there's a fan that runs continually while it's on. The manual does say to turn it off when not in use so that's what we want to do.
  • pasusan wrote:
    Ours is from 2004 (probably 2003) and there's a fan that runs continually while it's on..
    Yes, cheap inverters have continually running fans.
  • Thanks to everyone for the replies. I've got a better grasp on how folks deal with them and what we can do in our situation. :)
  • Mine is switched off because I camp long enough where 12 amp hours a day makes for a cumulative negative total.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
