pasusan's avatar
pasusan
First time with an inverter
Our Roadtrek has an inverter for the TV & DVD player. There is a switch to turn the inverter on and off, and the TV & DVD don't work unless the switch is on. So, even if we're on shore power we have to turn on the inverter to watch a movie. Problem is we forget to turn it off when we go to bed and it runs all night... The owner's manual says to be sure to turn it off when not using.
Is there a way to switch to shore power when we're hooked up or maybe get a lighted switch for the inverter so we are reminded that it is on?
How does the average inverter user handle this?
  • This average user usually leaves it on 24/7. Probably harder on them to be turned on and off frequently.
  • Most inverters (if they are of any quality) draw very little idle amps. I leave mine on, all the time I'm camping.
  • Leave the TV and DVD on and just use the inverter switch to turn them on and off.
    Our inverter runs other things too so we have to actually unplug the TV since it is still on in standby drawing power when it is "off"
    Sure.
    Plug the TV into a different outlet; one that is not fed by the inverter.
    OR plug a small night light into the same outlet off the inverter.
    It really isn't much of a problem as the inverter should not draw much power when there is no load.
    I solved this problem by getting a 12 V TV instead of messing with an inverter.
  • Mine is the same way. I did it because it is the simplest way so you don't need any transfer switches. If you on shore power, no need to turn it off. If you dry camping, it no biggee if you leave it on, just uses maybe a 1/2 amp of battery power.
    And yes, I do have a lighted switch for the inverter, and still forget to turn it off now and then,....its no bigee
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
