jrnymn7 wrote:
Thanks, Mex,
I was wondering if the resting V could hold strong while SG drops.
Most definitely! I've seen 12.8V on my batts with a 1.265 SG. Voltage doesn't tell me squat! I get more info looking at amps draw. If I see anything more than 0 amps on my Victron on float (technically this would be net amps), either I just came back from a boondock trip and the batts are not 100.000000000000000% full (after charging, batts on float I'll still get some NET charging amps for a day or two even if SG says they're full) OR I have a problem (had to fix TWO different wiring issues). I ONLY use voltage to see if the charger is running properly.
