Old-Biscuit
Oct 13, 2015Explorer III
AT 700,000 btu flow rate it is 3 1/2 times the flow for RV use. Plus it weighs 3.3 lbs (HIGH flow RV 2 stage reg......200,000 btu Typical is 160,000 btu.)
Sure you could use it....but it only has 1 inlet and 1 outlet so you would have to 'T' inlets for 2 cylinders (valve one in at a time ---no auto swapping) PLUS adapter fittings. And it would probably chatter due to the LOW demand in RV
Shop for a Cavagna 2 stage auto swap reg
LINK
LINK
