mena661
Sep 25, 2014Explorer
What I've found from the LI battery crowd is that larger capacities are not needed because the voltage drop under load is nearly linear as long as you stay away from the edges of the discharge curve. So smaller capacity LI batteries can handle MUCH larger loads. There's a guy running his microwave from a 200Ah LI batt. With LI, most of us could do a Landyacht and run a single battery and recharge it everyday via solar/genny.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
