vlopddap's avatar
vlopddap
Flame detector gauge not working on Norcold N300 fridge
Just tried my Norcold N302 fridge on gas for the first time yesterday night. This is the first time ever I use a gas fridge BTW. If it's matter the TT is 3 yo and fridge only worked on gas like 2 times by the former owner since he only use it on 120V.
After a few try I finally succeed on lightning it. Maybe it's normal since it's the first time it run on gas for many months/years. Only issue so far is the flame detector gauge that act strangely. At first when I finally succeed to light burner, gauge move slowly to the green section. At this time I gone outside to check by the burner hole and there's a nice flame inside burner. After a few minutes I decided to open the fridge (to check if I left some food inside, no particular reason...) and when I closed the door, the flame detector sensor return to the zero position (completely left on the white section) so I returned outside quickly and the burner was still working normally.
So what's the deal with the flame detector gauge, is it something sensitive to any small vibration near of it? Or it's like the old gauge that remain stuck and only work if you knock on the glass?
I finally turn off gas and switch back to 120V since I was tired messing around the RV for the day!
Any comments on the flame detector gauge? How does it work? Is it reliable?
Having RV issues? Connect with others who have been in your shoes.24,321 PostsLatest Activity: Sep 21, 2025
