Gdetrailer
Nov 22, 2014Explorer III
BuckBarker wrote:
Reverse one battery for storage, then turn the battery around the correct way when you need to use it. Fixed.
Nice try.
But, battery corrosion will still happen with DRY CELL BATTERIES once they get too old.
This happens whether you use them until flat or allow them to lay around for years until they go flat. Once flat they will eventually eat the battery case/seal and the caustic electrolyte migrates outside the battery.
It is for that reason most good name brand Dry cell batteries have a USE BY DATE on them.
Too reduce the chance of corrosion in flash lights or any battery powered devise you NEED to REPLACE DEAD or OUTDATED batteries as soon as possible.
To cut down on the chances on corrosion you could change to rechargeable NiMH batteries but you will need to recharge them every month or so since they will tend to self discharge themselves. You can buy Eneloop rechargeable batteries which have a very low self discharge rate.
ENELOOP BATTERIES
Rechargeables also have a very good low temperature operation which is very handy in extreme cold temperature usage!
My go to flashlight is my Makita 9.6V flashlight which uses the same 9.6V rechargeable battery as my Makita drill. I keep the flashlight in my truck under the seat. Even during the coldest days I can pull it out and still get several hrs of light. I just rotate a freshly charged battery into it once a month for good measure.
Dry cells tend to not work as well or not at all at extreme cold temperatures.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
