We_Cant_Wait
Sep 28, 2014Explorer
Rich, if you have an air compressor, pull the units outside tire up onto a couple of 2x6's, this will take the pressure off the inner tire, then let it set for a while. The tires are stiff enough that they'll usually reset to the rim so that you can air the inner tire up if it doesn't have a massive leak. When you air the tire up remove the valve to allow more air flow to help reset the tire. If it'll hold air this will allow you to drive the unit to the nearest truck tire repair service.
