BruceMc
May 01, 2013Explorer III
I mounted mine in full 1 1/2" aluminum rails on all four sides. The two running the length of the coach are mounted directly to the roof & properly sealed, where the two cross rails are mounted to the leading and trailing edges of the panel. Using 10mm stainless bolts and hard rubber spacers, I mounted the cross rails to the parallel rails.
The spacers hold the panels up about 5/8" off the roof so the breeze can blow through underneath while underway, and I can rinse the area underneath the panels when cleaning the roof.
This helps with cooling as well.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
