mchero's avatar
mchero
Fleetwood Entry Door Hinges
I'm having issues with the entry door on my 93 Fleetwood. The screen latch never has been properly adjusted. The other day I was looking at the three entry door hinges very cloesly. I noticed that the door lifts about 1/8th of an inch when closed. I'n not even going to think about adjusting the screen door latch untill I correct the hinge issue.
I was thinking about getting some E-clips and inserting them under the small washers that the three door hinges hinge on. I just need to get the proper size e-clips.
I ran across this site;
http://www.fleetwoodrvhinges.com/
and almost fell over when I added three hinges to my cart, $438.00!!
Just for yuks I added a roll of weather stripping, $75.00 for just the weather stripping!!!
Must be making a TON of money if people are really ordering these hinges! Did this website pop-up after Phillip's, the original manufacturer of these hinges closed down?
I would love to replace all three hinges BUT I'm not going to drop $438.00 PLUS on three hinges thank you.
I think I'll stick with the E-Clip idea.
Ideas, suggestions?
  • j-d's avatar
    j-d
    Explorer II
    I've done what Gjac did. Wish I'd had stainless washers, used ordinary steel, but the fix in fact DID work. Did it on our old 1984 Class C and a friend's BigFoot Truck Camper. I think that if you do the right split in the washers, maybe spread them a little beyond that, then pinch shut once in place, you'll get a longer-lasting fit than C-Clips would afford. I'd just think C-Clips would be quicker to come un-clipped.
  • Gjac's avatar
    Gjac
    Explorer III
    I did two things on my door that helped. I first lifted one corner and that stopped the scrapping. I then cut SS washers into a C and slid it between the hinge points then squeezed the C with a vise grip around the piano hinge wire. So far it is still holding after several years. If I was more ambitious or when the C clips fall out I would try enblethen's method. My doors are 16 years old.
  • The clips did not work for me. They popped out when they hung up on the hinge.
    That is why I drove pins out and used flat washers. The flate washer outside diamter is about the same size as the hinge rolled areas.
  • Yes I did see the post from my Camarillo friend! Surprised the E-clips did not work for you. I'll try BOTH e-clip & split washer fix.
    Thanks for the reply
    96Bounder30E wrote:
    Robert,
    Did you ever see the thread I posted about these hinges?........
    Hinge replacement
    Yes, you are right.........they are expensive.......but, they are the only source that I could find and they are VERY NICELY made.......I am 100% happy.......I have not looked back on my decision......
    I started with the C-clip route as well......that was a very temporary solution for me.......the C-clips kept rotating off of the hinge pin and would fall out......after repeatedly fussing with them over several months I resigned myself to the fact that replacement hinges were the only way to go.......
    I ordered a box of 100 C-clips........If I can find them......I would be happy to send them to you.......
  • I believe I need the Eclips! I can see a worn out section on the door sill were the door snubber is wearing.
  • This may seem crude, but sometimes the doors get racked from gravity and just need to be carefully unracked by firmly lifting the latch edge while it's open a few inches. Try to see where the contact is made that causes it to lift when first closed to determine whether to unrack or add E-clips
  • Mchero:
    Your hinges are probably like mine. Long about a foot piano type hinges.
    I drove the pins out. Got it out about an inch or two with drift. Then grabbed hold of pin with vise grips and drop almost out.
    I purchased a bunch of stainless steel flat washers. Used small jack to lift door up, Inserted enough between each hinge point to keep door up.
    I had to change the screen door latch out completely. Old one was a pain! Used one from JR products model 10765(?)
  • Robert,
    Hinge replacement
