BFL13
Dec 02, 2018Explorer II
If the load reduces the charger voltage so it is not the higher voltage, then the battery will have the higher voltage and get drawn from.
Perhaps you are just adding charger voltage to give it enough to run the loads and still maintain battery voltage.
Might be some voltage "as seen" from different places going on too making them look different, so the battery gets drawn down.
