wa8yxm
Feb 21, 2021Explorer III
mbopp wrote:
I just looked - the throat on mine is 1-3/8". No, it will not pass a tennis ball. Or women's sanitary products. Or anything solid, the steel impeller needs to grind it up to pass through the garden hose fitting. Once a year I disassemble it to remove the hair wrapped around the impeller.
Nice post but one nit. The impellers are rubber not steel. The Steel blades are the macerator, all they do is break up semi solids and stir the soup as it were. Below them is a metal plate and below that are the rubber impellers. Just so you know.
Other than that one nit. Good post.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
