mbopp
Dec 21, 2020Explorer
We'll camp for up to 2 weeks at a no-hookup campground. I use a Flojet to pump the tanks into a 30-gallon barrel mounted in the truck bed, and also for dumping at home. I made hoses from 3/4" corrugated pond or water feature hose since it's light, coils easily, and there's no back pressure on it.
I've had the pump for 12 years or so and had my first issue. Short story - several blades broke off the impeller and jammed the pump. I took the front of the pump off and managed to fish the blades out the discharge port. There were 2 blades left and that let the pump function enough to get me through the week. Flojet is a variation of a Jabsco pump so I ordered a Jabsco replacement impeller. Flojet says to use a 9/32" ignition wrench to hold the shaft while you unscrew the retaining nut but I clamped a large screwdriver in a vise and used the slot on the end of the motor shaft to hold it while I unscrewed the nut. Other than that it's a simple replacement.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
